1995 Toyota Corolla Fuel pump
66,000 MILES • 4 CYL • 2WD • AUTOMATIC
HARTLES99HIM
My wifes 95 corolla after a few days in the single digits refused to start after trying to turn over. The car was working perfectly fine prior. Battery is good. l suspect that the fuel pump froze up and may need a little tap by a rubber hammer.
I am not sure where the fuel pump is?
Dec 18, 2008 at 11:08 AM
ZACKMAN
  • 4,202 POSTS
Fuel pump is in the tank, and I hardly doubt that it is your problem. When the temp goes to single digit, battery is the first thing to go.
Describe how the car tried to start. Does it crank (healthy cranks) but the engine does not catch, or is is really slow cranks. Did you take the battery to get tested to know that it is good? How much cranking amp did it have when you tested it?
Dec 18, 2008 at 11:19 AM
HARTLES99HIM
[quote:e3acd99bf4="hartles99him"]Engine Performance problem
1995 Toyota Corolla 4 cyl Two Wheel Drive Automatic 66,000 miles
I am not sure where the fuel pump is?[/quote:e3acd99bf4]
The battery is fine, i wound up jumping up and down on the bumber for 1/2 minute with half of tank of gas and wahla it started right up and has ever since.
Dec 22, 2008 at 9:30 AM
ZACKMAN
  • 4,202 POSTS
I am glad that everything works out OK for you.
Dec 22, 2008 at 1:05 PM
