1995 Toyota Corolla 4 cyl Front Wheel Drive Automatic 114K miles
My Haynes manual does not explain the significance of a flashing MIL, and it continues to flash when I jump E1 & TE1. I can't retrieve any OBD I codes. This started with two separate incidents of hesitation, and the engine ran great prior to this. I replaced the distributor cap, rotor and plugs, and removed the battery terminal to clear any codes because I can't retrieve them anyway. After reconnecting the battery the flashing MIL returns as soon as the key is turned to on. Since the engine wasn't started I'm thinking the problem is a sensor. Do these clues point to any particular sensors to check first?
Monday, December 29th, 2008 AT 9:00 AM
