Hi kyhills, welcome to 2carpros and TY for the donation
One of the following below could be causing it Inspect and test all of it-
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage/vac leak
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
SPONSORED LINKS
Sunday, February 28th, 2010 AT 3:45 AM
