HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
1995 Toyota Corolla engine want crank
WINDY75972
MEMBER
1995 TOYOTA COROLLA
4 CYL
FWD
MANUAL
213,000 MILES
Not get gas to the engine
Saturday, October 25th, 2008 AT 9:29 PM
MMPRINCE4000
MECHANIC
Check fuel pressure with a mechanical gauge to verify no pressure.
If none, then you have a bad pump or fuse/relay.
Running the car out of gas will cause pump failure, since the gasoline cools the heat generated by the pump.
SPONSORED LINKS
Sunday, October 26th, 2008 AT 7:48 AM
Please
login
or
register
to post a reply.
Related Engine Content
1995 Toyota Corolla Engine
Looking For A Detailed Diagram Of My Engine A 1995 Corolla, 1.6l 4a-fe
Asked by
darklink
1995
TOYOTA COROLLA
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
Engine Life Of Toyota Corolla
My Car Is 1995 Toyota Corolla Lx. Its Run Mostly By Compressed Natural Gas(cng) As Well As Rarely With Octane. Does Only Cng Will Reduce The...
Asked by
haq_azizul
1995
TOYOTA COROLLA
Toyota Corola 1994 1.6 Engine
I Have A 1994 Corola Wgn 1.6 I've Changed The Plugs, Wires, Rotor And Dis Cap But My Car Runs For Maybe 5 To 10 Min Then Start To Bog Out...
Asked by
unko k
1994
TOYOTA COROLLA
Engine Cc Does Not Match Carb Cc - What Problems?
I Am In Bangladesh. I Have A 1988 Toyota Corolla Station Wagon. My Carburetter Had Problems (mechanics Told Me) So I Had To Go Buy A...
Asked by
DaveVera
1988
TOYOTA COROLLA
Type Of Engine
What Type Of Engine Does An '89 Toyota Corolla Have?
Asked by
mellisa89corolla
1989
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Hybrid Engine
Hybrid Car
Fuel Economy
Online car repair manuals
