1995 Toyota Corolla Engine stops after heat indicator shows
GETPREM
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • 110,000 MILES
I have a 1995 Toyota Corolla v4. I am changing the oil regularly every 3000 miles and neat maintenance.
Yesterday evening while I am driving all of sudden I got the Engine check indicator on, then Heat indicator show high then car stopped immediately. On the middle of the road, I don’t know what to do. Then I have started the car, it starts then I drive 0.3 miles to stop at the mechanic shop. This morning mechanic said, the core plug is failed, antifreeze is leaking, he estimated totally around $400, which includes (core plugs, head gas cut and labor).
Now I have no choice to move the car from that mechanic to another mechanic.
Could you please suggest what I have to do.
I really appreciate your help.
Thanks
Prem
Wednesday, September 24th, 2008 AT 8:55 AM
MMPRINCE4000
  • 8,548 POSTS
If the freeze plug is leaking, it must be replaced, the cooling system flushed and replace the thermostat.
Also check all hoses for bulging/cracking.
If the engine gets too hot for too long, you take the risk of blowing a headgasket or warping a head.
This will cost significantly more than $400 to fix.
Wednesday, September 24th, 2008 AT 9:07 AM
GETPREM
I really appreciate your rapid response.
To make clear to me,
Now I have to change the coreplugs
I have to change the head gasket
I have to change the hoses from the radiator to the engine.
Do I need to change the radiator also. If so how much it costs me. Do you have repair shops in East Rutherford, NJ, 07073 area.
If so please provide the details, I will be happy to get my car there for future repairs. I will recomend to my friends also.
Thanks
Prem
Wednesday, September 24th, 2008 AT 10:03 AM
MMPRINCE4000
  • 8,548 POSTS
You need to change the freeze plugs as you indicated they are leaking. Do not change the headgasket unless it is leaking, you can find out by having a compression test performed.
I would not change the radiator unless you see it leaking. If the hoses are original, I would change them.
After the freeze plugs are replaced, have the cooling system flushed and new coolant added and also change the thermostat.
Thursday, September 25th, 2008 AT 8:55 AM
GETPREM
Thanks for the reply. But it was little late for me. Just before I have pick the car from shop. Mechanic changed the headgasket ($72) and two core plugs ($25) and other small parts($40) and labor($235) total $377 charged.
He suggested, " Your vehicle is 110000 miles, so you need to change the timing belt and other tune up". That will cost again another $800.
I am not sure what to do. Do I need to do Maintenance repairs for 100000. What needs to be done.
Thanks for your time ahd prompt response.
Thanks
Prem
Thursday, September 25th, 2008 AT 10:32 AM
MMPRINCE4000
  • 8,548 POSTS
The timing belt should be changed at 60,000 mile intervals. If you have the original timing belt, yes it should be changed. I would also change plugs and wires every 30,000 miles.
Shop around for a better price, the price for the headgasket was certainly reasonable.
I would ask him what he is changing for $800.
He should have ask you about the timing belt when he changed the headgasket, since he had to remove the timing belt to change the headgasket.
Friday, September 26th, 2008 AT 7:56 AM
