HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
1995 Toyota Corolla elevtrical / fuel
DRKD73
MEMBER
1995 TOYOTA COROLLA
4 CYL
FWD
MANUAL
187,900 MILES
Car dies when driving down street. I have replaced ECM, cap rotor, plugs, plug wires. Can someone help thank you
Tuesday, December 22nd, 2009 AT 2:42 PM
MECHANIC
Check the fuel pressure to rule the fuel pump if okay start checking the ignition system
SPONSORED LINKS
Tuesday, December 22nd, 2009 AT 2:44 PM
MMPRINCE4000
MECHANIC
When car dies, spray starting fluid in TB, if it runs a few seconds, then fuel problem, otherwise ignition as Raz suggested.
Wednesday, December 23rd, 2009 AT 8:10 AM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
My Engine Stalls After Driving For A While
Car Runs Fine When Its Cold But After Driving For 15 Minutes It Will Sputter And Then Stall. I Have To Wait For It To Cool Down And It Runs...
Asked by
davok
8 IMAGES
1995
TOYOTA COROLLA
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
1995 Toyota Corolla Car Died Going Down The...
Never Had Any Trouble At All With This Car. Going Down The Road At About 75 Mph In 5th Gear The Car Lost Power, But All Electrical Stayed...
Asked by
capnsnappa
1995
TOYOTA COROLLA
1995 Toyota Corolla Engine Stops After Heat Indicator...
Hi, I Have A 1995 Toyota Corolla V4. I Am Changing The Oil Regularly Every 3000 Miles And Neat Maintenance. Yesterday Evening While I...
Asked by
getprem
1995
TOYOTA COROLLA
1995 Toyota Corolla Car Died But Was Running Quite...
Hey Guys Appreciate Any Help U Can Give, Spark, Gas, Timing, Right? I Have Gas At Injector Column, So I Scratched That, I Had Assumed It Was...
Asked by
injun
1995
TOYOTA COROLLA
1995 Toyota Corolla Car Stall And Smoke
Car Started Sputtering Then Stalled, Will Start But Not For Long. Car Was Smoking, I Took Air Filter Out And Smoke Was Coming Out Of...
Asked by
JADA24653
1995
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Check Engine Light
Check Engine Light Safe to Drive?
Code Read Retrieval/Clear Honda
Online car repair manuals
