1995 Toyota Corolla cooling fan wont turn on
1995 TOYOTA COROLLA
VMAX
Engine Cooling problem
1995 Toyota Corolla Front Wheel Drive Manual 200K miles
On this vehicle I replaced the cooling fan relay and the fan temp scensor and the fan does not go on. I tested the fan by putting it direct and it works just wont go on when the temp gets hot. What can it be?
Thanks
Feb 3, 2009 at 10:57 PM
MMPRINCE4000
  • 8,548 POSTS
There should be a fan switch in the thermostat housing assy. A one wire connector, if you disconnect the electrical connector, the fan should run all the time. Fan Switch:
https://images.2carpros.com/forum/automotive_pictures/108325_fan_switch_1.jpg
Coolant Temp. Sender:
https://images.2carpros.com/forum/automotive_pictures/108325_coolant_temp_sensor_1.jpg
Feb 4, 2009 at 1:58 AM
