1995 Toyota Corolla cooling
14,000 MILES • 4 CYL • FWD • AUTOMATIC
NICHOLUS.TAYLOR
The car continues to overheat, we have replaced the radiator and thermostat. The water pump seems to be working fine. The first radiator failed and we bought a second. It ran normal for a few days and then started to overheat rapidly. We keep the radiator full, I dont know why it still over heats? Should i replace the water pump?
Aug 7, 2010 at 9:24 AM
  • 75,988 POSTS
Retest the thermostat and also try bleeding it out don't work and the water pump is doing its job get it block and pressure tested to rule a blown headgasket, cracked head or block and an intake leak
Jul 27, 2020 at 9:43 AM
