1995 Toyota Corolla Clutch pedal and gear shift
143,000 MILES • 6 CYL • 4WD • MANUAL
SHARONTIMMOM
Car cuts off once in awhile in 1st gear and when restarted will not shift into any gear clutch has alot of play in it just started this problem after street flooded and had to drive through high water
Nov 22, 2009 at 6:56 AM
MMPRINCE4000
  • 8,548 POSTS
Check the clutch start safety switch.
Nov 22, 2009 at 11:10 PM
