1995 Toyota Corolla cluch slowly engages after pedal is pus
260,600 MILES • 4 CYL • FWD • MANUAL
SCHN
Hello:
I am the proud owner of a 1/4 million mile corolla.
For some time the clutch has been slowly engaging while the clutch pedal is pushed in. It does not leak any fluid and has never caused me much grief because I am used to it. My wife however.....
May 2, 2010 at 7:28 AM
  • 75,988 POSTS
Bleed out the old fluid and bleed it properly by sequence and see what happens
Note: When depressing the clutch pedal you are disengaging the transmission from the engine.
May 2, 2010 at 8:05 AM
