1995 Toyota Corolla Brake light on instrument panel
145,000 MILES • 4 CYL • FWD • AUTOMATIC
STRIKER300
Brake light on the dash is on all the time. Brake fluid OK. Haven't noticed any difference in brake pedal travel or in braking action. Replaced the parking brake switch. Still on after replacing switch.
Dec 31, 2009 at 11:59 PM
MMPRINCE4000
  • 8,548 POSTS
The light will also come on if parking brake is engaged. Try wiggling the parking brake lever and see if light blinks, if it does then PB switch is stuck.
Jan 2, 2010 at 12:42 AM
STRIKER300
I recently replaced the parking brake release switch and the dash light is still on all the time. I checked operation of the switch with ignition key on while I had the console cover off of park brake lever and it stays on constant. No flickering or momentary off/on of light on dash panel.
Jan 2, 2010 at 1:58 AM
MMPRINCE4000
  • 8,548 POSTS
So while you had console off the parking brake switch did not work?
The other swicth that activates the PB switch is the MC fluid level switch.
Also, when you tirn ign. to on does the battery light work?
A bad alternator will activate both the batt. and brake light.
Jan 2, 2010 at 11:27 PM
