how do i remove the existing interstate 75 month battery and replace with a like battery?
Jul 21, 2008 at 3:58 PM
✓Experienced Mechanic
Well disconnect the negative cable 1st then the positive-then connect positive cable to the new battery positive terminal and then the negative cable to the negative terminal- your done-
Jul 21, 2008 at 9:51 PM
PENNIMASI
MEMBER
[quote:eabdcaed6d="rasmataz"]Well disconnect the negative cable 1st then the positive-then connect positive cable to the new battery positive terminal and then the negative cable to the negative terminal- your done-[/quote:eabdcaed6d]
isn't there a third wire that connects to the alternator? if so, where is it?
Jul 22, 2008 at 5:04 AM
You should have a no.12 wire attached to the positive battery cable that leads to the fusible link then to the alternator fuse 100amp and back to the battery
