How do I remove the existing interstate 75 month battery and replace with a like battery?
Monday, July 21st, 2008 AT 10:58 PM
MECHANIC
Well disconnect the negative cable 1st then the positive-then connect positive cable to the new battery positive terminal and then the negative cable to the negative terminal- your done-
SPONSORED LINKS
Tuesday, July 22nd, 2008 AT 4:51 AM
PENNIMASI
MEMBER
Isn't there a third wire that connects to the alternator? If so, where is it?
Tuesday, July 22nd, 2008 AT 12:04 PM
MECHANIC
You should have a no.12 wire attached to the positive battery cable that leads to the fusible link then to the alternator fuse 100amp and back to the battery
