1995 Toyota Corolla Acceleration Problem
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
MERRITE
Thanks a bunch for providing this service. Car initially cranked this morning and was driven 5-6 miles. When attempted to turn a corner, engine and oil light came on and lost power. Car eventually died but re-started a few minutes later. Got on the freeway with no problem driving 55 mph for approx 15 miles. After existing and attempting to turn corner, same problem re-started. Car stalled with no acceleration but after a few minutes and a couple of tries at re-starting, the car started back up and slowly with a lot of hesitation drove a few more miles before making another turn. Car died again so problem seems to be whenever foot is released from gas pedal and pressed again. Started up again and finally made it to destination. Runs ok when in neutral but otherwise hesitates. Is this fuel filter, fuel pump, or possible injector problem? Again, thanks for all your help.
Eugene
Apr 26, 2008 at 6:53 AM
BMRFIXIT
  • 19,053 POSTS
as a 1st step i would check the EGR valve
check it for tune up too
Apr 26, 2008 at 10:50 AM
