1994 Toyota Corolla wheel lock up after replaced master cyl
139,000 MILES • 4 CYL • 2WD • AUTOMATIC
JSAN
Dear Carpros,
Recently the brake pedal began travelling excessively before braking the car. It appeared that only the left front brake was engaging but not the right. I had the master cylinder replaced which remedied the brake travel but now the right front brake is the problem. The right wheel gets hotter than the left and after 20min of driving any hard stop will result in a right front wheel lock up(a hard stop from 25mph). I had the car rechecked by the same mechanic who said everything was fine. What could be the problem?
Thanks
After the MC was changed I could drive the car the right front lock up began. I brought the car back. Both calipers and flex hoses were replaced because the problem was a presumed to be a stuck caliper. After changing the calipers and hoses, I drove the car 20miles when both front brakes overheated and siezed. The same mechanic said a pressure release on the master cylinder was not set appropriately after the caliper change and remedied the problem. He said the rotors and shoes were fine and only changed the setting mentioned. I drove the car for 20 miles again and no seizing ocurred but the original right front brake problem persisted. (After the brakes warm up, the right gets hotter and will lock up on hard stops)
Thanks again
Apr 9, 2008 at 1:08 AM
  • 55,676 POSTS
This happens when the brake booster push rod is adjusted out too far which does no allow the brake master to return fully holding the brakes on . To confirm the issue loosen the brake master mounting bolts 3 turns to see if the car starts to roll again, if so remove the master and adjust the booster push rod inward. Also a brake flex hose can come apart internally causing a short of check valve in the system but this is usually isolated to one brake either front or rear.
Mar 29, 2021 at 4:18 AM
JSAN
[quote:72b415a31e="2CarPro Ken"]Please replace both brake flex hoses. Please let me know[/quote:72b415a31e]
Thanks again
  • 55,676 POSTS
The master cylinder is not releasing completely leaving the pressure on the brake system, remove the master cylinder and readjust the control rod that pushes the rear of the cylinder, (make the rod shorter). this will allow the brake system pressure to release. please let me know
