1994 Toyota Corolla thermostat
185,000 MILES • 4 CYL • FWD • MANUAL
JDCOPE
Which radaitor hose is the thermostat located in the top or bottom. I know it will be on the end connected to the engine.
Jan 16, 2009 at 9:40 PM
MMPRINCE4000
  • 8,548 POSTS
Usually on this engine, the bottom. Follow the hose up, it will connect to a water housing, containing the thermostat, coolant fan switch, coolant temp switch, and guage temp sender. It is below the distributor.
Jan 17, 2009 at 12:31 AM
