1994 Toyota Corolla RE: Fuel Pump Location
150,000 MILES • 4 CYL • FWD • MANUAL
NIXAMUS
Toyota Corolla 94'. Engine stalled then wont fire. Good spark, compression. When i spray a fuel into air cleaner it will run then die when i stop. Removed fuel lines to engine and nothing comes out, how ever i dont know the location of the fuel pump. Is it in the tank, where do i access it from? Cheers
Jan 1, 2008 at 6:20 PM
  • 31,937 POSTS
Hi there,
The fuel pump is an in tank pump which you access via a cover plate under the rear seat.
Mark (mhpautos)
Mar 2, 2021 at 1:27 AM
  • 75,988 POSTS
Might have an access through the trunk or the backseat. if not siphon the fuel then drop the tank.
