1994 Toyota Corolla Fuel Intake
129,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRISP83
  • 11 POSTS
I would like to know the correct position for the pipe coming from the fuel filter to the injector rail.
I noticed that the pipe ends in an L shape, with a hollow screw that goes through it. The injector rail has a "notch/plate" going about 1/4 way around the circumference of the rail.
Is the L section of the pipe supposed to sit against this "notch/plate", or should it sit between the two ends of the plate?
Mar 23, 2009 at 4:50 AM
MMPRINCE4000
  • 8,548 POSTS
If I understand your question, the "L" fits in a notch to prevent the hose from turning when tightening.
Mar 23, 2009 at 10:44 PM
