1994 Toyota Corolla Fuel Filter Leaking
WIZZWAZZ
Engine Mechanical problem
1994 Toyota Corolla 4 cyl Front Wheel Drive Manual
I replaced the fuel filter on my vehicles, but after I installed the new filter as per the service manual, the bottom connected started to leak when the vehicle started and the engines runs.
What should I be looking for?
Thanks in advance.
Dec 22, 2009 at 4:01 AM
MMPRINCE4000
  • 8,548 POSTS
You may have crossthreaded the lower connection, or if the lower connection is a banjo bolt, it requires two copper crush washers for proper sealing.
If lower connection is double inverted flare (like a brake line) then is is most likely crossthreaded.
Dec 23, 2009 at 12:03 AM
