1994 Toyota Corolla Corolla making nclanking noise while AC
OSCARMALONZO
MEMBER
1994 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
229,000 MILES
1994 toyota corolla automatic is making a loud clanking noise while accelerating between 60 and 70 mph. Once I hit 70 mph, noise stops. What could be the problem? And how much would it cost to fix?
The clanking noise is coming from under the hood. But only when accelerating between 60 and 70 mph. Also, it makes a high ptiched whirring/whining noise when accelerating at lower speeds.
Wednesday, March 4th, 2009 AT 1:48 PM
MMPRINCE4000
MECHANIC
Can you tell if it is an engine noise, suspension, or maybe a loose heat shield on the exhaust?
Thursday, March 5th, 2009 AT 6:51 AM
OSCARMALONZO
MEMBER
Friday, March 6th, 2009 AT 10:20 AM
MMPRINCE4000
MECHANIC
Make sure the oil level and trans. Fluid are good. Check the belt tension. Check tensioners. Check motor mounts.
