1994 Toyota Corolla coil
1994 TOYOTA COROLLA
115,000 MILES • 4 CYL • FWD • AUTOMATIC
NESAN
  • 25 POSTS
Hello, I ahe replaced all four struts by KYB GR2. front in 2009 rear in 2008. I wish to insall mags 16 inch and 205 tries. By the way, is it good to lower the coils, because Ihave to replace the coils and I wish to use the low coil or adjustable coil. Is it Ok if I use my car to carry 3 peaople, adults, once the car is lowered. Will that hurt my car.
Jun 28, 2010 at 11:15 AM
MMPRINCE4000
  • 8,548 POSTS
Lowering will not hurt as long as you keep it reasonable. Too low and, and when you add weight you can bottom out suspension.
Jun 30, 2010 at 1:20 AM
