1994 Toyota Corolla clutch losing hydraulic pressure
80,000 MILES • 4 CYL • 2WD • MANUAL
BURKY39
when the clutch pedal is depressed and a gear is selected the clutch starts to engage even though the pedal remains down, i believe this to be due to damaged seals in either the master cylinder or the slave cylinder, my question is how do i tell which of these is more likely to be the problem?
Mar 7, 2010 at 12:33 AM
MMPRINCE4000
  • 8,548 POSTS
It would most likely be the MC seal, than slave.
Bleed the system, if there are no leaks, then MC.
Mar 8, 2010 at 12:23 AM
