1994 Toyota Corolla battery charge
14,000 MILES • 4 CYL • FWD • MANUAL
SEANMS
I have a dead alternator and want to charge the battery, so that i can get my car to the garage. i have a portable car battery charger that willstart the car. if i want to charge the battery should i hook it up to the car battery and not start the engine? since the alternator is shot does it make any sense to start the car?
Will i get a better charge from another car and if so will i be better off with the other car running or just battery to battery connect and neither car running.
please help i am not terribly savvy with this subject.
Thanks.
Sep 19, 2009 at 12:00 PM
MMPRINCE4000
  • 8,548 POSTS
Check with local autoparts stores about charging your battery for free.
Do not run engine very long with a bad alternator, if battery gets to low, it will have to be replaced.
Also do not use another car to start or run engine, you could damage the battery/alt. of the other car.
Sep 20, 2009 at 1:49 AM
