Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Tires
Rim
1994 Toyota Corolla
1994 TOYOTA COROLLA
115,000 MILES • 4 CYL • FWD • AUTOMATIC
NESAN
MEMBER
Hello, What size of rim should I buy if I want 205 size tires.
Thank you
Aug 19, 2009 at 10:57 AM
MMPRINCE4000
Experienced Mechanic
You can go up one width size without changing rim size, from 195 to 205. Larger would require one size larger rim width.
But always check to make sure larger tires will not interfere with fenders.
Most tire stores can give you wheel and tire info.
Aug 23, 2009 at 1:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
