1994 Toyota Corolla
1994 TOYOTA COROLLA
RUELL
Shakes or Wobbles problem
1994 Toyota Corolla 4 cyl Front Wheel Drive Automatic
The engine take a while before it starts and when it start it shake very bad and whobbels
Oct 19, 2008 at 12:15 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure with a mechanical gauge, if OK then remove spark plugs and look for gas soaked plugs/signs of misfiring.
You can also get a inexpensive tool to check spark on each spark plug.
Have coil tested and ignition module.
If coil or module test bad, replace them and replace wires, plugs, cap and rotor.
The motor mounts may be showing signs of wear, but getting it to fire on all cylinders will help alot.
Oct 19, 2008 at 1:19 AM
