1993 Toyota Corolla test
GHATMAIL
  • 9 POSTS
Electrical problem
1993 Toyota Corolla 4 cyl Front Wheel Drive Manual
Would you please guide me how I can test and be sure that the socket on brake oil reservoir and its junction cable are both healthy and work correctly?
This question is because now a days I replaced my brake master cylinder and I faced a little problem with its socket and I can't be sure if its socket works right or not. In this uploaded picture you see a socket on brake oil reservoir which I mean that.
Thank you so much[img:c425134f37]http://www.2carpros.com/forum/automotive_pictures/312898_Brake_Master_Cylinder_1.jpg[/img:c425134f37]
Mar 11, 2009 at 7:54 AM
MMPRINCE4000
  • 8,548 POSTS
The socket appears to be an electrical connection, probably a low level warning light.
If a remanufactured unit, you probably got a bad one, which happens more often than you would think.
Mar 11, 2009 at 5:40 PM
