1993 Toyota Corolla Speedometer
168,500 MILES • 4 CYL • FWD • AUTOMATIC
JWMATLOCK51
Question:
I have a 1993 Toyota Corolla DX, Automatic Trans. w/ overdrive. Problem is that the speedometeronly works when your speed is above 40 mph and then it drops to zero, and even then it seems to be showing a greater speed than it is actually.
Any ideas what might be the problem?
Thanks, Wayne/SLTCA
Nov 4, 2009 at 12:36 AM
  • 75,988 POSTS
Inspect and test the vehicle speed sensor
Jan 3, 2020 at 10:17 AM
EDWARD 18
check the wires of your speedometer sensor socket their are three wires red blue must be placed at the back near the fire wall if you check it with a multimeter it must have a positive power; red green at the middle must have a negative power: red yellow is thespeed indicator
