Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Computer
Monitor Not Resetting
1993 Toyota Corolla speed monitor
1993 TOYOTA COROLLA
195,600 MILES • 4 CYL • 2WD • AUTOMATIC
JOE_GINGER
MEMBER
1 POST
the speedometer does not work. Do you think it could be a fuse or the sensor?
Feb 18, 2009 at 11:27 AM
MMPRINCE4000
Experienced Mechanic
Check fuses first, then check wiring to VSS (speed sensor), if OK, then replace VSS. If problem persists, it could be the speedometer itself.
Feb 18, 2009 at 11:56 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
