1993 Toyota Corolla speed monitor
195,600 MILES • 4 CYL • 2WD • AUTOMATIC
JOE_GINGER
the speedometer does not work. Do you think it could be a fuse or the sensor?
Feb 18, 2009 at 11:27 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuses first, then check wiring to VSS (speed sensor), if OK, then replace VSS. If problem persists, it could be the speedometer itself.
Feb 18, 2009 at 11:56 PM
