1993 Toyota Corolla rack and pinion
161,000 MILES • 4 CYL • FWD • AUTOMATIC
JCBB589
tried to replace rack and pinion but, theirs 1 bolt
that holds me down, the bracket on the left side
that is too close to the transmission support bracket
, there is no room to remove the rack & pinion bracktet bolt due to thes problem, any suggestion
thank you
Apr 16, 2010 at 11:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
make sure you follow steps below, should allow access to all necessary bolts.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2012.jpg
Apr 16, 2010 at 2:13 PM
