1993 Toyota Corolla oil
1993 TOYOTA COROLLA
206,000 MILES • 4 CYL • FWD • MANUAL
SARAMV03
My car is using an excessive amount of oil and there are no visible leaks on the ground. I put a quart of oil in and drove about twenty miles and the engine was dry again. My oil light didn't even come on. Help, what is wrong. My car is running well.
Jul 20, 2008 at 1:04 PM
  • 31,937 POSTS
Hi there,
With that amount of oil consumption you must be driving around in a blue smoke cloud. It is either going out the exhaust or on the ground, and if it is not leaking then you have a serious problem. I would be getting the comps tested for ring failure first.
Mark (mhpautos)
Jul 20, 2008 at 1:40 PM
