1993 Toyota Corolla injector
COSTASS
  • 6 POSTS
1993 Toyota Corolla 4 cyl Front Wheel Drive Manual
Hello.
Did you know the quantity of spray nozzle (cc ) with codes 23250-11100.
thank you.
Nov 4, 2010 at 7:45 AM
  • 75,988 POSTS
There's no such codes-jumper the check connector Te-1 to E-1 and read the flashes-get a repair manual this will indicate where the problem lies with the 2-digit code
Nov 4, 2010 at 10:06 AM
MMPRINCE4000
  • 8,548 POSTS
If you are asking the injector capacity, i.e. lbs per hour, then I cannot find it anywhere.
U.S. cars measure injector capacity in lbs per hour (fuel).
Japanese cars are measures in cc's per hour.
Injectors are also high or low resistance, you cannot use a low resistance injector in a car requiring high resistance.
Nov 5, 2010 at 2:29 AM
