1993 Toyota Corolla high beams
AMEE43
Electrical problem
1993 Toyota Corolla 4 cyl Front Wheel Drive Manual
hi
i have a problem with my car when i push my high beams switch forward my high beams don't come on but the high beam indicator light works fine when i pull the switch back high beams work fine , all the other lights work fine
can some one pls advise me what the problem might bee
Aug 27, 2010 at 10:47 AM
MMPRINCE4000
  • 8,548 POSTS
The switch is bad or relay. Pulling back on stalk is "flash to pass" mode. High beams should stay on when stalk is pushed foward.
Aug 28, 2010 at 1:15 AM
