Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Fuel System
Fuel Pump
Replace/Remove
1993 Toyota Corolla fuel pump
1993 TOYOTA COROLLA
161,350 MILES • 4 CYL • FWD • AUTOMATIC
DANIEL143831
MEMBER
1 POST
how hard would it be to replace the fuel pump in my car,in other words, can you tell me how to do this?
Jan 22, 2010 at 10:21 AM
Experienced Mechanic
Look thru the backseat and trunk if there's an access door-none, you got to drop the fuel tank it can get tedious
Jan 22, 2010 at 11:04 AM
MMPRINCE4000
Also make SURE the pump is the problem.
You can short terminal +B and Fp at diagnostic link, if pump runs, pump is not the problem.
Jan 23, 2010 at 12:56 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
