I clean the air filter with an air compressor(high pressure air) every week. The air filter hasn't any dust but its color is light gray not white.
I want to know when is the best time to change the air filter?
And if an air filter is cleaned well by gasoline and air pressure(the filter color is changed to gray), can it be used again or throw it away?!
Sorry another question is: can we spray the engine body greasy cleaners on electrical wires or rubber hoses around engine or these cleaners must be sprayed just on metals and ...?
Thank you so much
Hatam Ebrahimi
Thank you so much
Hatam Ebrahimi
Feb 13, 2010 at 5:13 PM
