1993 Toyota Corolla Cold Acceleration Slip
BABERSHAREEF
I recently bought a '93 corolla DX,AT and lately I have been having a problem with the transmission during the cold starts, sometimes after the intial take off the engine just does not respond to the acclerator,i mean I accelrate but the car just does not go forward smoothly, instead it feels like I'm revving the car in neutral, the problem subsides after I stop the car for sometime and then go, its mostly during the cold starts. Can't figure out where the prolem is, is is the transmission? or a tune up will solve it? or is it connected to the speedometer malfunction problem I had earlier?
Wud be thankful if you could help me out
Feb 14, 2007 at 5:17 AM
  • 75,988 POSTS
[quote:d82d0deded="babershareef"]I recently bought a '93 corolla DX,AT and lately I have been having a problem with the transmission during the cold starts, sometimes after the intial take off the engine just does not respond to the acclerator,i mean I accelrate but the car just does not go forward smoothly, instead it feels like I'm revving the car in neutral, the problem subsides after I stop the car for sometime and then go, its mostly during the cold starts. Can't figure out where the prolem is, is is the transmission? or a tune up will solve it? or is it connected to the speedometer malfunction problem I had earlier?
Wud be thankful if you could help me out[/quote:d82d0deded]
Have these sensors check- throttle position,coolant,vehiicle speed sensors The computer reads their signals to operate the transmission- overdrive/upshift'/lock-up etc.
HTH-Good Luck
Feb 14, 2007 at 7:28 AM
Suggested Repair
Have the throttle position sensor, coolant temperature sensor, and vehicle speed sensor checked. The computer uses their signals to control transmission upshifts, overdrive, and lock-up.
Conversation Summary
The owner of a 1993 Toyota Corolla DX automatic reports that after cold starts the engine revs as if in neutral and the car does not move forward smoothly. The issue eases after stopping and restarting, and they ask whether it is the transmission, a tune-up, or related to an earlier speedometer problem. The expert advises checking the throttle position, coolant, and vehicle speed sensors because the computer uses those signals to control transmission operation.
