1993 Toyota Corolla correction on axle seal(oil seal) quest
1993 TOYOTA COROLLA
PAIGER
Transmission problem
1993 Toyota Corolla 4 cyl Two Wheel Drive Manual 260kms miles
Thanks for the reply mark. I am not sure if I was clear about the car being a front wheel drive. I received some replies about the differential, which would refer to a rear wheel drive car. I was wondering if what you said will applies to a front wheel drive car.
Do I have to take off the transmission case cover to get to the seal? Or can I just pop it out with the axle removed? Thanks, sorry for the confusion.
Oct 26, 2009 at 2:29 AM
DOCFIXIT
  • 18,828 POSTS
He meant to remove axle then seal can be removed by prying out with screwdriver. Install ues socket that is seal size tap in.
Oct 26, 2009 at 6:36 AM
