1993 Toyota Corolla BUCKING
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
JKCOROLLA
WHEN YOU TRY TO ACCELLERATE THE CAR BUCKS
AND TAKES LONG TO REACH THE DESIRED SPEED
EVEN AFTER WARMING IT UP SEVERAL MINUTES.
Oct 17, 2009 at 10:27 AM
  • 75,988 POSTS
Could be one of the following below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 17, 2009 at 11:05 AM
