1993 Toyota Corolla Axel nut
MIK9
  • 1993 TOYOTA COROLLA
Suspension problem
1993 Toyota Corolla 4 cyl Two Wheel Drive Automatic
I replaced my passenger side cv shaft assembly and can never get the AXEL NUT and RETAINER to get the correct tension. If I tighten it too much the wheel doesnt spin and if not tight enough it makes a clunking sound. Is there a corect protocol for this?
Saturday, February 13th, 2010 AT 12:58 AM
  • 31,937 POSTS
Hi there,
You will have a problem with the hub or bearing, as you can do these up dead tight with out a problem, I think you better check fore a problem around the bearing and retainer.
Mark (mhpautos)
Saturday, February 13th, 2010 AT 3:17 AM
MMPRINCE4000
  • 8,548 POSTS
These are equipped with a pressed in bearing, axle nut should be tightened to 100lbft.
As Mark pointed out you may have a problem with the bearing housing, like a cracked housing.
Saturday, February 13th, 2010 AT 7:57 AM
