1993 Toyota Corolla acceleration
200,000 MILES • 4 CYL • FWD • AUTOMATIC
VAMARASI_K
When pressing the accelerator pedal, the engine starves, the ignition timing retards before advancing and then the engine speeds up
Dec 8, 2008 at 12:26 PM
MMPRINCE4000
  • 8,548 POSTS
Check the engine timing, if OK, then check the fuel pressure with a mechanical gauge, If OK then check spark.
If you have a check engine light, get the codes.
Dec 9, 2008 at 1:06 AM
