1993 Toyota Corolla
TM7BALA18
  • 1993 TOYOTA COROLLA
1993 Toyota Corolla
How can you repair the door on driver side that can't open by a key.
Monday, July 27th, 2009 AT 10:05 PM
  • 31,937 POSTS
Hi there,
Is the key turning and nothing happening? Key wont turn? What is the exact problem?
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 5:38 AM
TM7BALA18
  • 7 POSTS
Hi there too! Yes key won't turn, door can't open.
Tuesday, July 28th, 2009 AT 2:14 PM
  • 31,937 POSTS
Hi there,
The lock mechanism has probably failed, can you open the door from the in side, as you will have to remove the door trim to access the lock,
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 4:23 PM
TM7BALA18
  • 7 POSTS
Yes I did open it but how can it be fixed?
Apreciate your info!
Tuesday, July 28th, 2009 AT 5:31 PM
  • 31,937 POSTS
Hi there,
With the trim off you will have to disconnect the link rod to the lock from the barrel & key, if the key still wont turn you will have to replace the barrel & key, check this next.
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 5:35 PM
