1992 Toyota Corolla transmissin feels like im pullin a 1000
MRCR6
Transmission problem
1992 Toyota Corolla Automatic 150000 miles
could the tranny pump have gone bad cause it feels like the tranny wants to lock up
THANX
Nov 2, 2008 at 6:53 PM
MMPRINCE4000
  • 8,548 POSTS
Check the differential fluid level. Toyota uses a seperate lubricant supply for the differential (where the axles go into the trans).
There is a fill hole on the rear of the diff. near the firewall.
I have seen this happen several times on the A131L trans. The diff. loses the lubricant (usually through bad axle seals) and without lube, the differential will eventually sieze.
I have to be honest, if it is the diff. it is probably too late. You will have to replace the trans.
Try a used one from a 90-92 Toyota Corolla or Geo Prizm. You can usually pick up a good one for $350 or so.
Nov 2, 2008 at 11:49 PM
