HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine Cooling
Thermostat
SPONSORED LINKS
1992 Toyota Corolla THERMOSAT
EDDIE H
MEMBER
1992 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
11,125 MILES
WHERE IS THE THERMOSTAT LOCATED ON MY ENGINE
Sunday, January 11th, 2009 AT 12:27 AM
BLUELIGHTNIN6
MECHANIC
The thermostat is installed on the inlet side of the water pump.
Thanks for using 2carpros. Com!
SPONSORED LINKS
Sunday, January 11th, 2009 AT 12:43 AM
MMPRINCE4000
MECHANIC
Make sure the replacement thermostat has a small air vent in the housing, This vent should be installed at 11:00.
If you cannot find a replacement with this vent, get one from Toyota.
Sunday, January 11th, 2009 AT 7:24 AM
Please
login
or
register
to post a reply.
Related Thermostat Content
1992 Toyota Corolla Purging Air After Thermostat &...
I Replaced My Thermostat (it Was Periodically Sticking Open) With A Genuine Toyota Stat & Also Replaced The Lower Hose. The New Stat Had 82...
Asked by
keepitrunnin
1992
TOYOTA COROLLA
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1992 Toyota Corolla Thermostat Housing
I Was Changing The Thermostat And One Of The Thermostat Housing Bolts Broke Off. It Looks Like The Bolt Is Inserted From The Backside...
Asked by
palmerpeak
1 ANSWER
1992
TOYOTA COROLLA
1994 Toyota Corolla Overheating With A New T Stat
My Car Was Overheating So I Replaced The T Stat And It Did Nothing, The Upper Hose Gets Hot But The Lower One Does Not. No Leaks, And No...
Asked by
mountainhomebands
1 ANSWER
1994
TOYOTA COROLLA
I Broke Screws Of Thermostat Housing, How To Replace
Hi I Own A Toyota Corolla 1995 Automatic With 155000 Miles On And Prtty Good Shape, A Week Ago Starting Overheating And They Recommended Me...
Asked by
gmante6309
TOYOTA COROLLA
Thermostat Replacement
I Was Wondering Where Exactly Is The Thermostat Located On The 1.6l Engine Of A 1996 Corolla?
Asked by
baker1996
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Thermostat Replacement Kia
Thermostat Replacement Mercedes Benz C230
Thermostat Replacement Chrysler
Online car repair manuals
