1992 Toyota Corolla Temperature getting high
GABO1957
Engine Cooling problem
1992 Toyota Corolla 4 cyl Two Wheel Drive Automatic 152K miles
I replace the radiator blower recently as it was bad,ever since the car temperature is raising every time, i check the blowers and sometimes is off/on can some one help
Mar 1, 2010 at 3:40 AM
MMPRINCE4000
  • 8,548 POSTS
Disconnect fan switch, directly under dist. turn ign to on, fan should run all the time.
Also remove radiator cap and make sure radiator is full, if not leave cap off and start engine and add until thermostat opens.
Mar 2, 2010 at 12:50 AM
