1992 Toyota Corolla Temperature getting high
GABO1957
  • 1992 TOYOTA COROLLA
Engine Cooling problem
1992 Toyota Corolla 4 cyl Two Wheel Drive Automatic 152K miles
I replace the radiator blower recently as it was bad, ever since the car temperature is raising every time, I check the blowers and sometimes is off/on can some one help
Monday, March 1st, 2010 AT 11:40 AM
MMPRINCE4000
  • 8,548 POSTS
Disconnect fan switch, directly under dist. Turn ign to on, fan should run all the time.
Also remove radiator cap and make sure radiator is full, if not leave cap off and start engine and add until thermostat opens.
Tuesday, March 2nd, 2010 AT 8:50 AM
