1992 Toyota Corolla Tail Lights
165,000 MILES • 4 CYL • FWD • AUTOMATIC
JWERNER26
The brake lights on my 1992 corrolla stay on when I turn off the car, I have checked all the fuses and non of them are blown. The emergency brake is NOT engaged, and my brakes seem to be working fine. I unplug the lights in the trunk so that it does not drain my battery but what would be the problem
Jun 8, 2009 at 3:47 PM
  • 75,988 POSTS
To do that either you have a defective brake switch or it needs adjustment to include the light failure sensor
Jul 30, 2019 at 4:05 AM
MMPRINCE4000
  • 8,548 POSTS
Yes as Raz said, it is brake switch, it can be readjusted. This is a common problem on older Corolla's.
