Could be a bad strut, wheel bearing or a control arm bushing, possibly a cracked brake drum, or broken hold down pin on the brake drum pads. Could also be a broken exhaust hanger.
Jack up the rear, check the wheel for any vertical, horizontal play and it should rotate freely. Inspect exhaust.
SPONSORED LINKS
Friday, February 15th, 2008 AT 7:22 PM
