1992 Toyota Corolla Signal Flasher
1992 TOYOTA COROLLA
110,000 MILES • 4 CYL • FWD • AUTOMATIC
DPRICE2008
Could you tell me where the flasher is located at in the car or what would cause the turn signals and the emergency flashers to not work at all inside or outside. Checked fuse and all is good there.
Apr 5, 2009 at 9:12 AM
MMPRINCE4000
  • 8,548 POSTS
Under dash, drivers side. You can remove the lower IP cover, under steering wheel for better access. It is a small silver can.
Apr 6, 2009 at 12:42 AM
