1992 Toyota Corolla Radiator Fan
158,000 MILES • 4 CYL • FWD • AUTOMATIC
SAD NAL
My radiator fan kicks in as soon as the car powers on and never stops even if the car has been sitting overnight and engine is cold. What do I need to do? replace relays? Fan fuses are not blown, could it be the fan itself?
Aug 26, 2010 at 1:41 AM
  • 75,988 POSTS
Could be the engine temperature gauge switch or the fan relay
Aug 26, 2010 at 6:28 AM
MMPRINCE4000
  • 8,548 POSTS
Check that fan switch (located under distributor in coolant distribution block) is connected.
It is white and round, if connected, then as RAZ said, stuck relay or bad fan switch.
Aug 27, 2010 at 1:20 AM
DEVO357
  • 5 POSTS
I located the fan switch and it is connected and I also located the relay, when I disconnect the relay the large main fan turns off (the one behind the rad) but the small one stays on same thing if I remove the main 30amp fuse for the fan large off small on. My question is How do I narrow down which it is the relay or the fan switch.
Help! and thank you!
Dean
Aug 27, 2010 at 7:13 AM
MMPRINCE4000
  • 8,548 POSTS
I would replace the fan switch. It is designed to run all the time if disconnected or switch is faulty.
Aug 28, 2010 at 1:17 AM
SAD NAL
[quote:c405c538a2="rasmataz"]Could be the engine temperature gauge switch or the fan relay[/quote:c405c538a2]
Thx Raz, I replaced the engine temperature gauge switch and the fan switch and both looked cruddy and needed to be replaced (corroded) but problem persist. I am about to pick up a relay and replaced that and we'll see what happens. Anyway, thanks for the advise.
Aug 30, 2010 at 4:29 AM
DEVO357
  • 5 POSTS
[quote:82dd1f50d7="mmprince4000"]I would replace the fan switch. It is designed to run all the time if disconnected or switch is faulty.[/quote:82dd1f50d7]
Thank you!
Dean
Aug 30, 2010 at 10:50 AM
MMPRINCE4000
  • 8,548 POSTS
If you have a local U PULL IT, go and find a 90-92 Corolla or Geo Prizm.
Remove the two fuse boxes to use as spares, (they just unplug).
They contain relays and fuseable links which are hard to find and VERY expensive it you have to get them from Toyota.
Aug 31, 2010 at 1:15 AM
