1992 Toyota Corolla oil in my radiator
1992 TOYOTA COROLLA
154,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERTBROWN31781
what problems could be the result of oil in my radiator. how can the problem be resolved and what cost am i looking at.
robert
Jun 15, 2009 at 4:18 AM
SARABROWNS
  • 27 POSTS
Assuming no one Put oil in there...not a good sign! Is there antifreeze in your engine? Did you recently overheat your car? I'm just thinking to when the head gasket blew on my Chevy...The only way I know of oil getting into a radiator is if it got in from a head gasket leak...
Jun 15, 2009 at 6:27 AM
MMPRINCE4000
  • 8,548 POSTS
As Sara said if it is oil then the headgasket, check the oil in the pan for a chocolate color.
If it is reddish, it could be the trans oil cooler is leaking inside radiator.
Jun 16, 2009 at 12:50 AM
